How to change front bottom light
Old Mar 28, 2016 | 10:23 AM
SCOODY's Avatar
Car: Z28 / 1984
Engine: 5L
Hi,
Can someone tell me how to hange the bulb light in this bottom front light ?
(see picture attached with red arrow)
From front , i can remove black plastic grid with 4 screws, then there are on the two vertical sides of glass some metalic parts but is i open them, i can't remove glass.
From behind layed under the car, i cant remove bulb also ...
Thanks for your help
Old Mar 29, 2016 | 09:03 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: How to change front bottom light
They look like OEM fog lights. Here is a youtube video from 1A
Old Mar 29, 2016 | 03:14 PM
SCOODY's Avatar
Car: Z28 / 1984
Engine: 5L
Hi,
It's not OEM Fog lights, it's a French car , and it's the "position lights" .
The ones that you switch on when it's just a little dark.
i can't remove it from behind like your youtube video....
Best Regards
Old Mar 29, 2016 | 10:51 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I brightened up the photo a bit so we can see the light you're referring to.
I'm thinking you can get to the bulb either from the top (in front of the radiator support) or from underneath. Either way, you're going to have to remove some of the plastic panels. I'm sorry I'm not much help.
Is that light a factory installed light for export models only?
Old Apr 10, 2016 | 04:36 AM
SCOODY's Avatar
Car: Z28 / 1984
Engine: 5L
Took time to look at today ...
Remove the four screws of the black grid.
Then push the up of the light to have him looking a little to the sky.
There is a bottom screw... in the middle.
87_gta
Jul 27, 2016 01:36 AM
Donald Croes
Mar 8, 2016 04:24 PM
mawaleegulu
Exterior Parts Wanted
Mar 4, 2016 12:19 AM
Racca116
Brakes
Feb 28, 2016 05:21 PM
86_firebirdTA
Feb 28, 2016 10:18 AM
