91 Firebird No power to fuel pump starter and coil
i am in the the process of swapping out my 3.1 to a 350. i have the ecm and wire harness from a 5.0 car. i have 95% everything hooked up and im down to starting it up. but when i turning the key on i hear no fuel pump, and starter doesn't even crank. i checked all the fusible links at the red wires after the links and they get voltage. i put power to the purple wire for the starter and it turns over. so the starters good. i put power to it all the way to the crank fuse ant it still works. and when its turning over it tested for spark at the coil and get nothing. and i don't even get a security when i turn the key on. is it a vats issue? vats worked with the 3.1 in it.
Re: 91 Firebird No power to fuel pump starter and coil
PS , don't know what ya mean by " 95% everything hooked up" , you should not even be connecting a battery to it till ya think ya got it 100% hooked up , and then troubleshoot from there .........
Either that, or one of the 2 (or 3? however many) fusible links at the starter, is bad or not hooked up.
Given that one fusible link powers one wire which goes to one cavity in C100 which goes to one big red wire under the dash which goes to the ign sw... all ya gotta do is start at the ignition switch and work your way back upstream toward the battery.
90 L98 TransAm
Exterior Parts for Sale
Mar 30, 2016 05:33 PM
