Does a 1985 Firebird 2.8 have a crank fuse?
Old Mar 21, 2016 | 02:11 PM
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Reason I'm asking is that on all the other diagrams it shows a crank fuse but not on the VIN S diagram. I'm wiring an alarm that interrupts the starter but it can only deal with 18 amps. If the wiring is a 3 amp load to the solenoid that's fine, but if it takes the full hit through the ignition switch that's like 200 amps!!
Any help will be greatly received!
Old Mar 21, 2016 | 02:21 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Does a 1985 Firebird 2.8 have a crank fuse?
see below
Old Mar 21, 2016 | 02:34 PM
So forgive me I'm wrong but according to those diagrams they're for an L4 not a V6?!
Old Mar 21, 2016 | 02:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Bottom line =
The only thing carrying something close to 200 Amps on startup are the two big wires from the battery . One to ground , one to the starter . ALL other wires in the car do not carry anything close to that kind of power . If you splice your starter interrupt in the circuit that engages the starter solenoid , the one that powers the solenoid's "S" terminal , you will have it in the right place .
Old Mar 21, 2016 | 02:56 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Whoops. 1st mistake I made today!
http://www.austinthirdgen.org/index.php?pid=19
Old Mar 21, 2016 | 02:57 PM
Thanks for the info. Any idea how much the solenoid pulls?
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
tater
Apr 28, 2016 04:30 PM
Lurbie
Mar 21, 2016 08:57 PM
cannibaljeri
Mar 20, 2016 02:26 PM
liva687
Mar 16, 2016 09:00 AM
