Deleting stock wiring.
Old Mar 28, 2016 | 11:41 AM
BeyondZ28_85's Avatar
Car: 85 Camaro Z28
Engine: 400 SBC .040 over bore
Transmission: TH350 (TH400 on the way)
So I've pretty much completely rewired my car after doing an engine swap. I ended up with a bunch of relays and wires for my Holley Black electric inline fuel pump, dual fans, and tach. So I started running my wires from the connectors and relays and zip tied them together to make a harness. Then I shortened them up once I ran them where they needed to go. I was also changing the heater core so I had to get into the ECM and remove it anyway. The car still works perfectly with the ECM removed. I think I want to wire the fuel gauge up and delete all of the stock wires other than those for lighting. Has anyone done this before?
Old Mar 28, 2016 | 11:47 AM
Car: 85 Camaro Z28
Re: Deleting stock wiring.
Also, the car is carbureted now so I don't have to worry about any of that. My fans don't use any of the stock wiring because my car had a mechanical fan. I had to wire up the sending units and that's all in my harness as well. I wired up my distributor myself as well. So I think everything in my engine compartment is stand alone. That's why I want to get rid of all the old wiring I don't need. Once I have it all, I'll see if anyone wants to take that stuff off my hands when I know what all I have.
Old Mar 28, 2016 | 12:31 PM
bschafert's Avatar
Car: 91 RS
Transmission: Soon to be T56
Axle/Gears: 3:23
my car has been running for the last few years on a painless fused switch board. This summer i plan to go through it and remove all the unecessary wiring to clean it up a bit. How deep are you planning on going?
Old Mar 28, 2016 | 12:45 PM
Car: 85 Camaro Z28
I'm going to make my own gauge cluster by buying the gauges and fabricating a dash out of a sheet of aluminum. I plan to delete all of the stock wiring possible and make my own. I'm going to wire everything myself. I already have my fans, fuel pump, and tach wired into a switch in the cabin. I'm going to wire my stereo to my accessory switch in the ignition. Pretty much I'm going to delete everything and run my own and make a diagram for it all.
2012sergen11
Apr 25, 2016 02:55 PM
1988_f-bird
Mar 7, 2016 08:29 PM
redwolf7374
Feb 22, 2016 07:42 PM
B4C5.7
Feb 20, 2016 02:48 PM
82Brlinetta
Feb 14, 2016 08:53 PM
