87 IROC 5.7 TPI Odd issue.
Old Apr 4, 2016 | 05:53 PM
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
I have a 87 5.7 TPI Iroc that is giving me some odd issues. So, I have a slightly rough Idle with the check engine light on (no codes stored) but, the car still has most of it's power. Then, the check engine light will go off and, have a completely smooth idle but, is totally gutless. When that happens I also get a very strong Catalytic converter smell. This happens intermittently for as long as a couple minutes and, as short as a few seconds.
Any ideas what may causing this? Been scratching my head all week and, have came up short on a fix.
Old Apr 5, 2016 | 04:36 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 87 IROC 5.7 TPI Odd issue.
Based on that description,......... my first GUESS is a bad ECM.
Old Apr 5, 2016 | 10:24 PM
hilltop530's Avatar
Engine: 5.7 TPI
the ecm is good. the ignition at the on position has the check engine light then shuts off when the car is fired. I think I found it. It would seem that a purge valve wouldn't let the fuel vapor into the charcoal canister. So, it was over pressuring the gas tank. Then once the pressure got to be so great, it would release and, flood the canister which flooded the throttle body, then down to the cat. I loosened the gas cap and, it all went away. so, it's down to a cleaning or replacing of that purge valve. Hopefully that does it. cheap fix right there.
gmglenn99
May 13, 2016 12:59 AM
tognabologna87
Mar 24, 2016 04:41 AM
'91CamaroRS
Mar 16, 2016 09:07 AM
herb17024
Mar 15, 2016 08:16 AM
AmpleUnicorn88
Brakes
Mar 15, 2016 07:04 AM
