Tach Board
Old Apr 6, 2016 | 12:27 PM
Lar98ss's Avatar
Car: 68 Coupe, 69 RS/SS, 91Vert, 98Vert
Engine: Several
Tach Board
Is it possible to just swap out a bad tach board for a working board? Or should a board and Tach unit be swapped together as a unit? Are they calibrated together or will work independently?
Old Apr 6, 2016 | 01:02 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Tach Board
Pretty sure that you can simply swap the tach board without any problems. You would have to use the same type of board,... V6-to-V6 or V8-to-V8 so the reading is accurate, but swapping similar boards should work.
Old Apr 6, 2016 | 06:07 PM
Lar98ss's Avatar
Engine: Several
Re: Tach Board
Yes, I agree V8 for V8, but just trying to confirm. Has anyone tried this?
89TA WS6
Apr 20, 2016 09:37 AM
Cehbra
Apr 9, 2016 04:19 AM
Ellis87z28
Apr 7, 2016 06:50 PM
firebirdpower7
Carburetors
Apr 6, 2016 08:00 PM
Spenc247
Apr 3, 2016 03:09 PM
