Tail light wiring
Old Apr 23, 2016 | 01:11 PM
Accerrito22's Avatar
Car: 1987 Iroc camaro
Engine: 383 Stroker
Tail light wiring
My car had no wiring and no connectors. Got this one off a buddy anyone know what all the wires are for?
Dark green ,light green, red and white, two yellow both solid yellow and a brown
Old May 2, 2016 | 05:24 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Telling The Tail
You can use a 12 volt fused source to probe which wire illuminates which bulb.
Just connect ground to ground
(black wires in most cases) then using the + wire from the supply, touch the unknown wires.
When the bulb illuminates, attach a label to the wire.
As far as the car you’re working on, if there is no taillight assembly on it at this time, you can find out what wires illuminate what bulb by using a voltmeter or clip on lamp then label those wires.
Happy Racing !
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
project89
Jul 2, 2016 01:08 PM
Kohn
Apr 18, 2016 08:58 PM
Tempest89
Apr 18, 2016 04:53 PM
EastonFrench
Apr 17, 2016 10:51 PM
PunchNugget
Apr 17, 2016 03:54 PM
