Digital Dash Odometer Bulb question
Hey everyone, I have the digital dash taken apart on my 88 GTA and I was wondering if anyone knew what bulb illuminates the odometer section. I can't seem to find anything online. Advance Auto and NAPA have nothing like the bulb. And the dealer is closed today.
Does anyone know the part number?
Andrew
Andrew
Car: Red 1991 Firebird with digital dash
Engine: L03 V8 TBI
Transmission: 700 R4
Re: Digital Dash Odometer Bulb question
You're lucky I have the digital dash apart right now. I took a picture of the original bulbs behind the odometer. These are in fact simple 194 wedge bulbs, also called T10.
I myself am planning to replace them with LEDs like for example these: https://www.superbrightleds.com/more...rofit-car/199/
Engine: L03 V8 TBI
Sorry forgot part number: GE 168 (General Electrics), here is a replacement incandescent bulb:
https://www.amazon.com/GE-NIGHTHAWK-.../dp/B0017OFS3C
http://www.digikey.com/product-searc...=0&pageSize=25
A 194 (EXTREMELY common automotive bulb, there's probably at least 15 of those in your car and maybe 20) will also work.
I doubt you'll be happy with LEDs... the color rendering is usually VERY disappointing.
Thanks for the response guys. I was talking about the bulb that lights up the odometer/trip info gauge. Mine has a bulb with two prongs sticking out of it. Not the normal 194 which is in the main cluster. It uses a different twist on plug thing also.
I couldn't find a replacement, so I ended up using a 194 bulb along with the plug for it. It got the job done.
Engine: L03 V8 TBI
So far things are looking good with some of those newer leds. Gonna spice it up with some white background job on the housing though. I'll post up once it's workin
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Engine: L03 V8 TBI
Anyways for the record, it is a GE 882 bulb with 4.5 Watt. No idea why they would put in one different bulb among four standard 194. Maybe height considerations?
https://www.amazon.com/MINIATURE-BUL.../dp/B0046IOWME
The digital cluster on my 1988 GTA has the same bulb behind the odometer section as WNYTransAm described that backlights the mileage. I haven't gotten a replacement for mine, yet.
I had another look at my digital dash and there is a bulb that looks like the one you are describing, however it wasn't on the odometer section but behind the oil pressure gauges...
89irocz355
26
Sep 12, 2016 01:28 PM
