Speedometer/power issue
Old Jul 8, 2016 | 12:34 PM
detaeyel's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
I have a 1989 2.8L Camaro RS. She's been having all sorts of issues but the newest is power surges and trouble accelerating. This is coupled with my speedometer jumping all over the place. Mechanic replaced the speedometer with a used one. It was good for a couple hours then started jumping all over the place and the power surges came back at the same time. I realize this could be a bad speedometer also. Has anyone else had this problem? Are we missing something?
Thank you :-)
Old Jul 8, 2016 | 01:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Speedometer/power issue
Speedo and the power problems are most likely not related. The speedo is a mechanical set-up so either the cable wasn't properly installed, ( could be installed wrong on either/both ends ) was bent at some point or is worn internally. I'd disconnect & inspect at both ends ASAP..... If it was installed improperly at the tranny end it might harm the speed sending unit / Speedo gear,... adding 1 more thing that needs to be replaced to your list.
Old Jul 10, 2016 | 03:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe some ideas in the following link:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
89iroc89
Feb 4, 2017 07:44 AM
Pilotrick50
Jun 14, 2016 10:08 AM
edpontiac91
May 18, 2016 09:43 AM
Eric-86sc
Apr 3, 2016 09:56 PM
84TransAm
Aftermarket Product Review
Jul 17, 2001 07:36 AM
