Power Pulleys: Good or Bad?
I'm looking at a pulley that goes in front of the harmonic balancer that is supposed to "turn 25% slower than stock and provide about 15 extra horsepower, which will give me better mileage and increased accessory life"--According to Summit.
Does this sound right or is it total BS? I'm not looking to put any hard parts on right now, the engine has a good intake and exhaust. I'm just looking at this for something extra before i plunge into something larger like heads/camshaft.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
350 ready to get in and run as soon as i find a WC T5.
--Steve S--
i had some on mine and ended up taking them off because it really f***ed with the charging and caused the idle to be really bad. oh and i didnt notice a difference with them on either.
'89 firebird formula tpi
custom cold air,gutted maf(just screens),52mm tb,ported plenum,edelbrock runners and base,headers with 3" catback,tb coolant bypass,afpr@44 psi,msd 6a w\blasterII coil,3.73 posi,sf connectors and corvette servo
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
I have a March crankshaft pulley on mine, but I didn't put the bigger alternator pulley on it so it keeps charge very well, It does help the engine rev. faster and it seems to get a little better mileage. I have never had any charging problems with it, but it did almost overheat one time when I was on vacation and drove it fast up Pike's Peak, it didn't turn the waterpump fast enough to keep the engine cool at VERY high altitude(12,000 to 14,000 ft.)
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
T-Tops
3.08 Posi-trac
Crane cam
HyperTech Chip
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
I've got a SLP 25% reduction pulley on mine with all other pulleys stock and it works fine. Performance wise I can't tell because I made some other mods at the same time. But the charging system is good, and it does not overheat.
YEP!
84 Camaro ZZ4 with HOT cam. Ported Heads, Installed Larger Race-Flo Valves, RPM Air Gap Intake, and 1 3/4" SLP Headers (Best 60',Quarter Mile, MPH) (1.88, 12.91, 106.77)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
The Bowtie
the reason i think i had probs with the charging system is because i but the alternator pully on to. But i might try just the crank pully now. Since uyou guys dont seem to have a prob.
Later Barrett
Later Barrett
Car: 2002 SOM z28
I have a 25% crank pulley and did notice a butt-o-meter difference I think. I have slight charging problems, but who idles or runs below 1200 rpms for very long anyways. I usually cruise around 2000, so it is fine at that rpm. I do have a cooling problem and that really irritates me.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
IROCZDAVE (88-L98)
08-06-2015 03:51 PM
