Wire Harness Tape
Old Jul 17, 2016 | 05:46 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Wire Harness Tape
Hey guys,
What is your favorite high quality electrical tape for use on the harness under the dash and in the engine bay. Looking for something that will hold up well to heat and not fall apart. The 3m stuff you can buy at the hardware store work ok until it gets hot. Ive heard of friction tape or tape with very little adhesive.
Any advice?
Old Jul 17, 2016 | 08:01 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Wire Harness Tape
I've used this over the years. Just used a little of it on the power antennae harness. No adhesive....you tie off the ends, just like the factory did. With no adhesive, there's no sagging or moving when hot. Not cheap, but it's the real deal.
https://www.npdlink.com/store/produc...-106731-0.html
https://www.npdlink.com/store/produc...-106732-0.html
Old Oct 2, 2017 | 12:32 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Has anyone else used this stuff or have something they recommend? I'm pulling off the factory (LS1 body harness) stuff and it leaves a sticky residue. Regular 3M stuff gets gooey with heat.
Old Oct 2, 2017 | 12:37 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Its the real deal, it works
Old Oct 2, 2017 | 02:34 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Look up Tesa wire loom tape. Does a excellent job on wiring harnesses.
siuol
Car Audio
Apr 23, 2016 08:50 AM
Garett92Z
Dec 5, 2001 08:11 PM
Blade
Jul 28, 2000 06:19 PM
