remote dimmer
Old Aug 1, 2016 | 12:38 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
remote dimmer
I've read every article here , of which there are many.
Issue is intermittent dash lighting on my 1988 digital dash.
Questions are.. Is it possible for the transistor to be bad if it's an intermittent problem? After testing I assume this is a pnp transistor and the third leg is the base itself ? Anyone know of a good source for this part? May be in my best interest just to replace it to eliminate that being my problem
Old Aug 3, 2016 | 12:45 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: remote dimmer
I've always found the Dimmer to be good or bad. Never dealt with an intermittent failure with a Dimmer circuit.
You might have read thru this already,... but here's what I learned about the Trans Am Digital Dash and the Remote Dimmer:
https://www.thirdgen.org/forums/inte...ital-dash.html
** I still have not yet tested my theory, or modification,........ To allow the dash backlighting to work when the PARK lights are ON and the key is NOT turned.
Old Aug 3, 2016 | 01:00 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: remote dimmer
I just happened to drive mine today. I have a flickering light bulb behind my odometer panel. But mine is a bulb/socket problem.
Check the ground wire under the dash pad/center.
Old Aug 3, 2016 | 07:10 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Re: remote dimmer
After pulling everything apart. concluded that it is not the light switch or the remote dimmer. Seem to have an intermittent power problem to the dash lights. When I wiggle the cluster it lights up. All gauges in the cluster works fine, backlighting was/is the issue
89irocz355
Mar 28, 2018 08:24 PM
89irocz355
Exterior Parts for Sale
18
Apr 11, 2016 10:17 PM
Brian28166
Mar 30, 2016 03:09 PM
workingonapos
Mar 22, 2016 10:14 AM
vortech305
Aftermarket Product Review
Mar 8, 2001 07:57 PM
