Horn Problems
Old Aug 18, 2016 | 09:18 PM
Destinejade's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH700R4
Horn Problems
I am having trouble finding the horn relay location on my 89 camaro rs. The horn hasn't worked since i bought the car in may. the person I had bought from also has electrical tape holding the center cover on the steering wheel. any thoughts? I use the car as a daily driver right now because i have no other car to drive, but i am planning to restore it on a later date.
Old Aug 18, 2016 | 10:37 PM
TPI Sierra's Avatar
Car: 1989 GMC Sierra
Re: Horn Problems
The relay is located behind the instrument panel to the right of the steering column with the turn signal flasher and such.
Old Aug 19, 2016 | 07:03 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Horn Problems
the electrical tape covering the horn button likely required removal of the horn relay...to keep the horn from blowing all the time, like. might be why you can't find it.
Look in the trunk or center console.
Old Aug 19, 2016 | 08:25 AM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Axle/Gears: 9 bolt 3:23
Re: Horn Problems
Located in the "convenience center" see post 2
Old Aug 19, 2016 | 12:07 PM
naf's Avatar
naf
Re: Horn Problems
Not if it's been removed...
I've got one in a box in my garage. I know because it has a piece of tape around it that says "horn relay".
Old Aug 19, 2016 | 12:28 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Re: Horn Problems
How do you know his convenience center has been disturbed. Why would it be in his console or trunk, R U the PO of his car ?
Old Aug 19, 2016 | 12:34 PM
naf's Avatar
naf
Re: Horn Problems
Certainly don't know, but if electrical tape is holding the horn button on, there is a high probability that it was making constant contact and could have been removed to stop the horn from blowing...
so there is a greater than zero chance that it is no longer located in the convenience center.
Old Aug 19, 2016 | 05:13 PM
scoflaw's Avatar
Car: 1988 gta
Engine: 383
Re: Horn Problems
Horn button ??? Horn relay... Don't really know by your terminology what the eff your talking about.
May not be located in the convenience center but it may be in the console or the trunk..?. WTF ???
Old Aug 19, 2016 | 05:21 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Horn Problems
I would suggest getting a Haynes manual.my horns didn't work because of a broken plastic part that rode on the contact ring on the steering wheel .I had to fabricate a part to make it work. That is likely the case for you as well, which is why the tape was there.
Old Aug 20, 2016 | 08:27 AM
naf's Avatar
naf
Re: Horn Problems
Don't feel bad, I often don't know myself but...
The horn button, or switch, is under the center cover of the steering wheel.
The horn relay is energized by the horn button, which sends power to the horns behind the left front fender.
Since the OP's horn button is held in place with electrical tape, it is possible that the PO removed the horn relay to keep the horn from blowing continuously or intermittently. If the relay has been removed it won't be found in the convenience center, but 'may' still be in the vehicle somewhere.
An example of at least one instance where the relay would not be located in the convenience center, which invalidates a proposed universal truth.
RSarge
Apr 6, 2016 08:32 AM
Bluestreek
Apr 1, 2016 02:03 PM
That Sky Guy
Mar 15, 2016 07:40 AM
Sharky
Aftermarket Product Review
Jun 19, 2001 06:33 PM
