very odd turn signal issue
Old Aug 31, 2016 | 08:51 PM
OG85cam's Avatar
First off thank you for allowing me back after many years of being away, was 85 cam originally but cant recall that password.....
Anyway new to me 92rs, was a 3.1 car now swapped over to a common sbc. my issue is that of the front drivers side turn signal
when the 4 ways are on all the correct lights blink except for the front drivers side and left turn indicator in the cluster. rear blinks and all the front passenger side.
turn the stalk to left hand turn, rear blinks as it should but the front does not, also no indicator in the dash. No marker blink nor big 2057 bulb under the headlight
Have swapped around bulbs to no avail. Any common places to look for lost signal?
Old Sep 1, 2016 | 09:28 PM
OG85cam's Avatar
Re: very odd turn signal issue
any help to be had out there?
Old Sep 2, 2016 | 11:59 AM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Check the wiring diagrams to see if you can trace the wires to find a break. Austinthirdgen.org has all the wiring diagrams for your car. HTH!
Old Sep 2, 2016 | 12:04 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Axle/Gears: 3.07
Looked at the drawings and see that the turn/hazard switch is the common point. Do a continuity test between the switch and the turn signal bulb to be sure the wiring is intact before you replace the switch. GL!
Old Sep 2, 2016 | 07:38 PM
OG85cam's Avatar
thank you both very much, I will work on this some more when the hurricane passes on thru here.
Old Sep 3, 2016 | 09:26 PM
G.Penrod's Avatar
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
Maybe try splicing another ground into the drivers side turn signal and ground it somewhere and see if that helps.
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
Dletts
Mar 26, 2016 10:56 PM
soulreaper
Mar 26, 2016 06:36 PM
herb17024
Mar 20, 2016 08:25 AM
trafficlightguy
Mar 15, 2016 03:10 AM
