85 t/a Cluster / check engine light don't work
Old Sep 23, 2016 | 09:21 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Ok, so screwing around with the head light switch, I figured I would look into why the check engine light don't work. The only lights that come on are the dome light, no interior lights, no cluster lights, the park brake light works, and turn signals. I have replaced the bulbs, and no go. What do I need to look at next? The fuses I found are good.
Thanks.
Old Sep 24, 2016 | 04:18 PM
HellHound's Avatar
Re: 85 t/a Cluster / check engine light don't work
I picked up a new switch and dimmer module and it still don't work.
Old Sep 24, 2016 | 08:23 PM
G.Penrod's Avatar
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
Maybe check to see if they share a ground wire and see if that ground wire has lost it's contact.
Old Sep 24, 2016 | 10:29 PM
HellHound's Avatar
I got the lights going. There was a crap alarm in it. Some how when I pulled that out and put in a junk yard dim mod in it they worked. So maybe a combo.
However I still DO NOT have a check engine light with key on. I NEED TO SEE THAT LIGHT. It is bugging me bad.
Old Sep 25, 2016 | 07:53 PM
HellHound's Avatar
I have found a few wiring diagrams. One I don't know if it is right or not. One shows the check engine light is in the aldl in pin D, going into slot five. And it is spliced off. What is SES LP? What is connector A with a lot 5? Now if I run a wire from the aldl in pin D and to a ground with a bulb connecting the two I should get a light right? If this is the case I could run a single wire to the cluster. But this is assuming that this diagram will work. I dont know if it will or not. Or maybe some one can steer me in the right direction?
Pictures of the two wiring diagrams I found. The cluster one is right. The check engine light has a black and white striped wire. It is not cut and the connector looks good.
Old Sep 26, 2016 | 03:30 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
BE SURE to follow wiring diagrams that are accurate for your car...........
If you follow the wrong schematic you could REALLY screw something up simply because the wiring was changed and you to tried to "jump" the wrong circuits with power or ground
Have you checked for an ECM ??
Have you replaced the Check Engine Light Bulb yet ??
Old Sep 26, 2016 | 12:26 PM
HellHound's Avatar
Well that is not very clear. I am hoping some one has a year specific diagram. I can rewire a car from scratch. So I am not afraid to burn some **** up. I do get what you are saying though. I would rather not make an educated guess and would rather know for a fact.
The only other thing close to this I have found is that the data storage chip might be toast. And if I am burning my own proms it should not be too big of a deal.
But at this point in time I have found no breaks in the wiring.
Old Oct 29, 2016 | 03:00 PM
HellHound's Avatar
Well I have stripped a bunch of stuff down. This is an ecu problem. It has a remain ecu in it. The CEL is ground control and #39 to the CEL is a hot, the ecu turns the cell on and off by the ground. #39 remains a constant hot always with key on. Off when key off.
Next problem, the ecu seems to be for a manual transmission. Would it run a auto?
Old Oct 29, 2016 | 03:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
My '89 Firebird was the same way. The check engine light had 12V on it from the fuse box and the circuit was grounded by the engine ECM.
I ended up repurposing that light as an alternator charging indicator with my LS swap because it seems these days that any time somebody fixes anything in a thirdgen that it ends in an LS swap.
Old Oct 29, 2016 | 03:47 PM
HellHound's Avatar
Ok cool. At lest I know that is what it should be doing. I just don't know if there is any other problems. It is easy when the ecu tells you there is something wrong.
I have thought about an ls swap. Just not sold on it yet. The cost of an ls swap I would be 350 and turbos ahead...
Old Oct 29, 2016 | 06:38 PM
John in RI's Avatar
Wonder if the M/T ECM has the Torque Converter lock-up circuits ????
Old Oct 30, 2016 | 01:49 PM
HellHound's Avatar
How do I know if the circuits are there? I don't need to fry the trans.
Old Oct 30, 2016 | 07:18 PM
HellHound's Avatar
Thinking on this, this could be a reason my car over heats while driving and not while it sits there at idle.
91phoenix
Fabrication
48
Jul 22, 2021 06:01 PM
Galaxie500XL
Aug 25, 2016 12:42 PM
1-Skip
Aug 21, 2016 09:42 AM
Eli Delgado
Aug 13, 2016 04:05 PM
soarestransam
Brakes
Aug 7, 2016 08:56 PM
