Aftermarket wiring question
Old Oct 10, 2016 | 04:37 PM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
Hooked up multi colored gauges. Works perfectly...except they go back to blue (default color)
So if I select say yellow. Turn the car off. then turn the key to "aux" they are still yellow, but when cranking the car to start, they go back to default blue.
The company said the power wire needs to installed on a constant power source...what would "lose power" just at cranking.....thoughts?
Old Oct 27, 2016 | 05:05 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Color Me Accessorized
You need an “always hot” line.
Such a line can be found at the fuse block accessory fuse.
Connect the memory wire to the output side of that fuse.
You can use the terminal labeled “bat”.
That and all similar lines will go lower in voltage when the engine is cranked.
Hopefully the memory circuit is not to sensitive, but if it is we can draw or describe a circuit which stays at 12 volts while the engine is being cranked.
Happy Racing !
“Professional Maniac Here, Do Not Drive 330 MPH In Your Own Home”
Nighthawkf-117
Sep 6, 2016 07:21 AM
Ryan-87GTA
Car Audio
Sep 4, 2016 09:58 PM
Monte66
Aug 29, 2016 05:11 PM
WNYTransAm
Interior Parts Wanted
Aug 20, 2016 10:03 AM
LDR
Aug 7, 2016 09:30 PM
