Cooling fan problems
Old Dec 29, 2001 | 03:00 PM
blasticblazin's Avatar
I have a 92 camaro Rs with the 305. I cant get the electric fan to work. I put a new motor and a new fan relay in and i cant get it to work and the motor keeps overheating. Cna anyone help please?
Old Dec 30, 2001 | 01:10 AM
multi-tasking's Avatar
No offense....But...Get yourself a Chilton's. Section 6-190 and 6-191 diagram how the coolant fan's electrical system should work. Try to isolate which of the components has failed --- is not connected---or not functioning properly. Sorry, that the best I can do...
I had the same problem a couple of years ago. The fellow that worked on the car replaced the fan motor, relay, yada yada yada and did not fix it... I got the car back found a charred wired and I repaired it… Third Generation Camaro is the best car one can own., but they are not replace a part and see if that fix it type cars…You can burn up a lot of cash that way.
Wish I could help more….
m-t
Old Dec 30, 2001 | 05:26 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Try hooking 12 volts up to the fan from the battery to test the fan motor.
Old Dec 31, 2001 | 10:31 AM
Actually, hooking a 12 v source directly to the fan motor is a good idea. If the fan motor comes on., next check the ECM to ensure it is energizing the fan circuit (relay). Just ground the "test" terminal -- turn the ignition key to the "ON" position (don't start the car). The fan(s) should come on. If the fan(s) does not come on you will need to check for bad relay and/or a shorted-open circuit(s).
v/r
m-t
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
JHX
Aug 29, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
