Fuel Pump Cut off switch for added anti-theft
Old Feb 15, 2017 | 12:26 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
I would like to create a fuel pump cut off switch in my 91 RS to add some additional anti-theft security.
I know that there is a relay that is between the fuel tank and the passenger seats on the outside, does anyone know which wires I would extend into the interior to put on a simple switch to interrupt power to the fuel pump?
My plan is pretty simple:
extend the harness and drill a hole for it to go through into the passenger compartment and take it to the ash tray between the back seats. So to start, simply reach back, open the tray, flip the switch, and start the car as normal.
Eventually I'll also do a push button start, but for now this will do.
I'll happily write it up if anyone would like after I'm done.
Old Feb 15, 2017 | 05:12 PM
Re: Fuel Pump Cut off switch for added anti-theft
There is no "relay" there. Only a feed-through.
A relay is an electrically operated switch. A small signal sends a little bit of current through its coil, which is a solenoid or electromagnet; the armature, i.e. moving magnetic part, has contacts attached to it, which then control a MUCH higher power circuit.
If you just want to add an extra intermittent (bad connection that works sometimes but not others) to randomly disable your car at the worst possible moment, it would be better to do it on the control side of the relay, rather than the high-power (fuel pump feed) side. Look at the relay, which is near the brake booster; find the coil wires; put your intermittent fault generator there.
Old Feb 15, 2017 | 06:02 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Put a piece of poop on the front seat and nobody will mess with your car.
Old Feb 15, 2017 | 07:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
LOL
Old Feb 15, 2017 | 08:56 PM
Hey I resemble that remark!!! I'm not gonna go sit in d00d's car just in case the thief comes along right then!
Old Feb 16, 2017 | 11:18 AM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by Falconiroc
.........in my 91 RS to add some additional anti-theft security...........
Provided your VATS is working , no "crackhead dentpuller to the ignition moron" is gonna drive off in your car because no one of that type would have the slightest clue of to how to defeat VATS and actually get the engine running .
And
If a "pro" car thief sets eyes on your car , they're just gonna show up at 3:42 AM , winch it up into some box truck specifically designed for the purpose of stealing cars , and be gone in 10 seconds or less .
Old Feb 16, 2017 | 12:38 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
alrighty then. Thanks.
Old Feb 17, 2017 | 01:49 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
And
Towing the car is much easier and faster and quieter than breaking in, fidling with wires and hoping it drives away. If you have a tow truck NO ONE thinks twice that illegal is happening. Watch a YouTube video of how fast an ordinary tow truck can remove a vehicle.
Best way to combat vehicle theft is a GPS based system that is well hidden and has it's own power source. The thief may still find it but at least you have a chance...
