Blowing fuses on contact
Old Dec 30, 2001 | 01:31 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
My 20 amp fuse that runs the itnerior lights and radio stuff is blowing as soon as I put one in.
I tried unplugging my radio and taking all interior bulbs out but it still does it. What could be blowing this fuse.
Old Dec 30, 2001 | 01:49 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Try taking out the cigarette lighter.
Old Dec 30, 2001 | 04:48 PM
86FyrBrd's Avatar
as soon as you said that I was convinced that was it and went out to play with it....turns out that isnt what it is, still confused.
what else is on that fuse
Radio
Interior Lights
Cigarette Lighter
Old Dec 30, 2001 | 05:19 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
This is everything on that fuse:
- Delco Amp relay
- Horn relay
- Horn
- Under hood light
- Hatch release relay
- cigarette lighter
- Outside mirror switch
- Door locks
- Dome light
- Map lights
Your radio is on your radio fuse not the ACC fuse. If your fuses are blowing the sec you put them in it is a short somewhere grounding the circuit.
Hope that helps
Old Dec 30, 2001 | 09:28 PM
86FyrBrd's Avatar
if my radio isnt on that fuse, and all others are fine, why is my radio dead too?
Old Dec 31, 2001 | 12:22 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Is it the stock radio? If so do you have the bose sound system? If you have the stock radio and the bose sound system the bose speaker amps are powered by the ACC fuse but the radio is on the radio fuse. If it's a stock radio without bose then it should work fine unless the radio fuse is blown on the fuse panel. If it is a aftermarket radio there is a fuse normally on the back of the radio or on the wiring harness that you should check. But the radio is not on the ACC fuse unless changed by someone.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
indygene
Sep 26, 2015 11:21 AM
