1989 trans am antenna motor clicking
Old May 23, 2017 | 07:39 PM
fshutz's Avatar
This should be a good one for all 3rd gen techs out there. This 89 trans am (5.0l TPI, Auto) has a working oem antenna motor w/ all wires (green-white-gray) properly hooked up & no previous alterations. The antenna motor clicks about every 60 seconds and heats up but works perfect. It gets worse: This is happening with the keys out of the car!!!
I have since pulled the fuse obviously as I trouble tree this thing. Im open for any suggestions!! Thanks in advance fellas.
Frank
Old May 23, 2017 | 07:54 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: 1989 trans am antenna motor clicking
It could be something to do with the motor switch. I actually just bought an oem switch off ebay a while back. Im pretty sure this is one of the parts that goes into them when they get refurbished. Maybe its sticking or something. I havent ever looked closely at one.
Old May 24, 2017 | 05:00 AM
fshutz's Avatar
Do you have any more info/link/part no. for that switch? I was hoping maybe it was just the relay to the antenna-which I ordered anyway. Thanks man
Old May 24, 2017 | 09:45 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Here you go,
Id go around with a test light and see where you have power and when. Also listen to where the noise is exactly coming from. The antenna should only turn on and come up when the radio, not cd, but tuner, am/fm is switched on. Do you have an aftermarket radio? If I remember correctly there is a power lead from the antenna that hooks to the back of the radio along with plugging the antenna cord in.
I bought this switch a while back and I'm not sure if you can get them anymore. I'm sure someone makes them. Careful if you take it apart as there is a glass tube that is part of the switch that could break. Also, just looking at my nos part, the brass contacts are corroded so check yours out. Some scotch bright will do the trick.
Hope this helps.
Dan
Old May 25, 2017 | 01:29 PM
fshutz's Avatar
My man all I can say is this is EXACTLY the type of response/information I was looking for. Thanks a ton !!! And to answer your question it is currently the factory head unit (never taken out yet) and I'm looking to replace it with after market.
Old May 25, 2017 | 01:45 PM
fshutz's Avatar
I'm thinking the switch inside the motor as well. Ive been combing the net based on the numbers on the delco box (in your picture) & cant find anything-even close!
Old May 25, 2017 | 02:36 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Old May 25, 2017 | 06:27 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
You keeping the radio?
When I came across the switch I swooped it up right away. I'm sure there are people/parts out there. I see refurbished antennas on ebay all the time. Spendy tho. 250-280 with core. So if they want a core there must be parts. Maybe contact one of the guys selling them on ebay and see if they can guide you. I've never had the pleasure of working on one yet.
Glad I was of some help. If you need better pics I can get some. I see some are a tad blurry.
Old May 26, 2017 | 12:32 PM
fshutz's Avatar
I always keep the radios, I have a few. You need one? Thats a good idea, I'll get ahold of one the guys rebuilding them- hopefully theyre as cooperative as youve been. I assume the 2 numbers on the top of your box are good. What is the number (GR # 9 647 ) between the 9 & 6? Do I have that correct?
Old May 27, 2017 | 10:56 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
It is a tad warn, but I'm 99% sure its 9-647.
In my GM Dealer book, they use the 22038191.
I snapped a pic that will have every part number and description for our antenna's from my book for you.
Old May 27, 2017 | 10:58 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Oh crap, you have an 89... Let me get the correct numbers. Geeze... Sorry.
Old May 27, 2017 | 11:13 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Here...
This will have every antenna part from 82-92
Your antenna part number is at top.
I highly recommend finding one of these and getting it. Make sure it has BOTH part numbers AND ILLUSTRATIONS. Lots of them are only part numbers.
Old May 28, 2017 | 07:53 AM
fshutz's Avatar
Your not kidding Dan, I want those books !!!!!
Old Jun 2, 2017 | 10:08 AM
GeneralDisorder's Avatar
You can probably fix it if you open it up. I was able to repair my OEM antenna with a new nylon pusher and some cleaning/regreasing. The contacts probably need cleaned, etc.
GD
Old Jun 15, 2017 | 06:57 PM
fshutz's Avatar
All I can say is the BEST guy to send this to is -
Barney Eaton
20111 Deerfield Dr
Georgetown TX 78633
512-869-5114
He is very fair and knows exactly what he is doing. I strongly recommend anyone that is having antenna issues to utilize his expertise!!!
Old Jun 16, 2017 | 04:54 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Barney Eaton
20111 Deerfield Dr
Georgetown TX 78633
512-869-5114
That's who did mine. Details in my build thread. Highly recommended.
Old Jun 16, 2017 | 06:36 PM
OR you can just buy a brand new OEM antenna. Yes they still make them. For some reason the manufacturer seems to have forgotten these were used in F bodys. They sell them for Jeeps. This is a 100% identical to OEM unit:
Amazon Amazon
Here's a good price on eBay too:
http://www.ebay.com/itm/Crown-Automo...JVV6T3&vxp=mtr
GD
Old Jun 16, 2017 | 11:33 PM
fshutz's Avatar
unfortunately the dude is 78 years old. His type is a dying breed of quality and fairness.
Old Jun 16, 2017 | 11:35 PM
fshutz's Avatar
Thats a excellent point GeneralDisorder. I consider that option strongly but the seller insisted they were for Jeeps only. He wasnt even interested in the sale.
Old Jun 16, 2017 | 11:49 PM
I looked into it and there are threads here and elsewhere that prove it's the same. And I can tell you from personally rebuilding mine (before I found out about this option) that by appearance alone it's identical. Here's one thread as evidence. Just Google the part number and "F body" for more:
http://www.turbotransam.com/forum/in...-antenna.7708/
GD
Old Jun 23, 2017 | 02:58 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
According to my book, there are several different antennas GM used from 82-92. Not saying the one on ebay wont work, cause it looks darn close, poss use it for parts, but its def not the same according to my book.
Old Jun 23, 2017 | 03:04 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
I bought 2 of the Crown units last year. Only difference is the finial is a tad bigger and the harness on it is a tad shorter. Same antenna. Buy it or fix your old with the steel cable mod. I have all kinds of spares now.
Old Jun 23, 2017 | 03:05 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
GD
That is my write up on it. Any info not there, just ask me.
