Ignition actuator
Old Jul 20, 2017 | 11:29 AM
My82Berlinetta's Avatar
Car: 1982 Camaro Berlinetta
Engine: V6
Ignition actuator
1982 Camaro Berlinetta V6 Automatic 43,000 miles all original three (3) owners.
When replacing my ignition switch, the ignition actuator rod disconnected from the ignition key lock cylinder and I am trying to reattach it. I have removed the steering wheel and have loosened the first housing but I can not seem to get the housing completely off. The turn signal is preventing it from sliding all the way off. Also, once this is removed, there is another housing that needs to be removed (circular one further down the column) and I am not sure how to remove this. Thank you in advance.
Old Jul 20, 2017 | 11:42 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Ignition actuator
Old Jul 20, 2017 | 11:47 AM
Engine: V6
Tuned Performance,
My apologies, I am learning how to use the site, this is my first day on here. When replacing my ignition switch, the ignition actuator rod disconnected from the ignition key lock cylinder and I am trying to reattach it. I have removed the steering wheel and have loosened the first housing but I can not seem to get the housing completely off. The turn signal is preventing it from sliding all the way off. Also, once this is removed, there is another housing that needs to be removed (circular one further down the column) and I am not sure how to remove this. Thank you in advance.
IROCDINOSAUR
Mar 5, 2017 01:53 PM
dragsta
Jan 25, 2017 07:05 PM
Slayze
Dec 26, 2016 08:29 PM
Cole Curtis
Dec 9, 2016 04:22 PM
julyburnsred16
Nov 28, 2016 10:27 PM
