Gear speed sensor to hall effect
Old Sep 10, 2017 | 06:34 PM
Gray Ghost 8991's Avatar
Car: 1991 Camaro RS
Engine: 355 TPI
Transmission: 700R4 or 4L60
Is it at all possible to change from a gear style speed sensor to a hall effect style sensor. I've found a hall effect sensor that will fit in the 700r4 extension housing (1988 C1500 sensor), not sure on what kind of reluctor ring I'll need yet. The sensor is a 2 wire and the plug is the same as what's on our cars. But will this work ? I already have an SGI5E and my car has the VSS buffer box. Thanks in advance!
Old Sep 10, 2017 | 06:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Gear speed sensor to hall effect
Yes, you can cut down the ratio using the SGI5E and split it using the buffer.
Old Sep 10, 2017 | 11:32 PM
Car: 1991 Camaro RS
Engine: 355 TPI
You wouldn't happen to know what size reluctor ring I would need would you ?
Old Sep 11, 2017 | 08:26 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't think a 2 wire is Hall effect.
Old Sep 11, 2017 | 08:58 AM
Car: 1991 Camaro RS
Engine: 355 TPI
I didn't think so ether but that's the only thing it could be from what I've researched. If you Google 1988 C1500 speed sensor you'll see what im talkin about
Old Sep 20, 2017 | 12:01 PM
Car: 1991 Camaro RS
Engine: 355 TPI
Confirmed fix!
I was able to use a 1988 C1500 reluctor ring and speed sensor on my 1991 RS. In addition to the speed sensor and reluctor ring an SGI5E from Dakota digital is required. The way I wired mine is as follows.
I tapped into the yellow wire that runs from the speed sensor to the VSS buffer box an plugged the send side of the wire into the "signal" input and the other side into "out 3" you will be able to a just it from there. You can also see application 3 in the instruction sheet for the SGI5E. Also this Here is the number on the tail shaft housing I'm assuming is the P/N 8673553-2.
Old Sep 22, 2017 | 10:05 PM
jmd's Avatar
jmd
Good work.
Old Sep 23, 2017 | 07:01 AM
Car: 1991 Camaro RS
Engine: 355 TPI
Good work.
Thank you sir I hope it saves someone else some time
