Engine won't turn off
Old Sep 28, 2017 | 08:56 PM
twentyyearwait's Avatar
Car: 1984 Z28
Transmission: TH350
I have an 1984 Z28 that I just put a 350 in. The key starts the car but does not turn the engine off. Any ideas?
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine won't turn off
Bad ign switch.
Old Sep 28, 2017 | 09:17 PM
NoEmissions84TA's Avatar
Did you install an MSD ignition box at the same time?
It is common for the alternator to back feed through the ignition box and keep the engine running. The fix is to install a diode.
Old Sep 29, 2017 | 01:40 PM
As always, see my signature.
Changing those parts didn't make the parts, or the design of the system, suddenly defective. That is not "the simplest explanation".
The simplest explanation is a workmanship issue.
Check for a short between the "motor" terminal of the solenoid (the one with the little copper strap going into the motor body) and the wire to the S terminal. Wire wrapped around something, loose strands, hooked up wrong, etc.
It's not impossible that the solenoid itself is bad, but it isn't as likely. Probably the second most likely: 95% chance it's wiring, 5% the solenoid, 0% anything else.
Old Sep 29, 2017 | 07:54 PM
Did he mean continues to crank, or continues to run?
Old Sep 29, 2017 | 07:56 PM
Right: sorry. That's what I get for doing this on a phone. Ignore me.
Old Oct 8, 2017 | 09:27 PM
Car: 1984 Z28
Transmission: TH350
Found the problem, fan was back feeding into the system
Old Oct 8, 2017 | 09:37 PM
Yes, that'll do that also. I assume you added a relay?
Old Oct 9, 2017 | 08:00 AM
Car: 1984 Z28
Transmission: TH350
I did, thanks for your help.
