Did any 3rd-gen come with electronic cruise?
Old Nov 29, 2017 | 05:57 PM
gtopat's Avatar
Engine: LO5
Transmission: 4L60
I'm swapping TPI into my Caprice and I'd like to retain the cruise control. My car has the AC "Electro-Motor" cruise box used on a bunch of the B-bodies, trucks, and I think 4th gens got them.
Did any third-gen come with the electronic cruise? Or did they all get the vacuum system? Just wondering if I can hunt for the right cable, or if I'll have to build something.
Thanks in advance.
-Pat
Old Nov 29, 2017 | 06:30 PM
Drew's Avatar
Re: Did any 3rd-gen come with electronic cruise?
Vacuum. But it's not a big deal, the system works fine, if you can mount a vacuum valve to the brake pedal anyway. Or figure out what vss signal your cruise uses and determine if tpi can send it.
Old Nov 29, 2017 | 06:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Some tpi maf with the 1227165 ecm non cable drive used a vss buffer .
The 730 ecm cruise output is pin c1
Old Nov 29, 2017 | 07:01 PM
gtopat's Avatar
Engine: LO5
Transmission: 4L60
Nuts. Looks like I'm making a cruise cable!
Thanks guys.
Old Nov 29, 2017 | 07:39 PM
Drew's Avatar
True, but the cruise control system is the same from 84-92.
Fabbing a cable shouldn't be a big deal. The aftermarket cruise systems just use a bead chain from the cable to the throttlebody. So just clip the existing cable in the bracket, hook up a chain, and hook the loop to the chain at the required length.
