86 trans am headlight problem
Old Dec 19, 2017 | 06:10 PM
Fannsi's Avatar
hey I have a 86 trans am that turns on the headlight bulbs but will not flip them up. All three relays are getting good ground and 12v on the always hot wire. When I removed the headlight assembly I tried to connect the motors straight to the battery and then the lights came up and then I needed to switch the wires and then the lights came down. What could be the next step in troubleshooting this problem? Would be nice to make them work again. Can I test the relays?
Old Dec 25, 2017 | 03:17 PM
Fannsi's Avatar
Re: 86 trans am headlight problem
When I connect 12v to the pink wire on the relay all three relays click but nothing happens/it does not move the headlights up or down.
Old Dec 25, 2017 | 03:27 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Maybe your bushings are toast?
Old Dec 25, 2017 | 03:31 PM
Fannsi's Avatar
But both motors turn up and down when I connect directly 12v to them
Old Dec 26, 2017 | 08:55 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Troubleshooting Headlight Doors for the 86 Firebird
Location for the Isolation Relay on a 86 Firebird
1 Quick T/A
Jan 27, 2009 06:05 AM
Jammen Firebird
Jul 19, 2007 09:14 PM
Zrated83
Oct 5, 2003 08:21 PM
