85 Trans Am Tach Reading 2x or more Actual RPM
Old Mar 1, 2018 | 07:06 PM
2012sergen11's Avatar
Car: 1987 Trans Am
Started up my freshly rebuilt 350 yesterday and the in dash tachometer was reading ~2500RPM at idle but 850 on the timing light and around 4500 at ~2000RPM on the timing light.
I've read through some threads on here but the only fix i have found is replacing the tach with another good unit or an aftermarket unit. Is there any good way to fix the stock tach or do I need to find a replacement?
Old Mar 1, 2018 | 07:15 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 85 Trans Am Tach Reading 2x or more Actual RPM
https://www.thirdgen.org/forums/engi...achometer.html
chevman24
Apr 2, 2009 10:14 PM
boldguy
Mar 4, 2009 04:41 PM
RedIrocZ-28
Aug 29, 2002 06:17 PM
