Power window relays
Old Mar 16, 2018 | 11:51 AM
Gary L's Avatar
Car: 1984 Camaro
Engine: 305 V8
Power window relays
1984 Camaro. Where are the relays for the power windows located? I took out my center console in order to install a new emergency brake lever. When I reassembled the console the power windows would not work. I checked the fuses and they are all OK. Could i have shrted out the relays?
Old Mar 16, 2018 | 01:33 PM
Drew's Avatar
Re: Power window relays
There are none.
Old Mar 16, 2018 | 01:38 PM
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
Are the wires connected to the switches correctly?
Old Mar 16, 2018 | 01:52 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Yes. The switches are a source of resistance, as is the under sized wiring for the distance and draw, there is a considerable drop at the motor.
Old Mar 19, 2018 | 01:14 PM
Gary L's Avatar
Car: 1984 Camaro
Engine: 305 V8
[QUOTE=Drew;6207849]There are none.[/QUOTEUs Is it possible to have shorted out the motors for the windows? Also, one of the switches came apart as I was removing it. I snapped it back together and using a volt/ohm meter I was able to determine that the switch was operating correctly. Also, of the four connectors per switch only one has power. Thanks!
Old Mar 19, 2018 | 01:16 PM
Gary L's Avatar
Car: 1984 Camaro
Engine: 305 V8
Originally Posted by Drew
There are none.
I was beginning to think that there were no relays.
Old Mar 19, 2018 | 01:26 PM
That would be correct: 1 power, 1 ground, 2 motor leads.
Yes it is always possible that a motor has failed. Not likely that taking out the console would have caused that though.
Old Mar 19, 2018 | 08:17 PM
Drew's Avatar
It's more likely that the circuit breaker in the fuse box has left the building. Look for the metal can labeled WDO. But then I'd expect if you have power at the switch, the breaker is probably OK. Might want to check the ground. It should be under the console, so it's conceivable that could have been damaged.
DynoDave43
Members Firebirds
1283
Apr 17, 2026 04:43 AM
92fbodylover
Exterior Parts for Sale
17
Mar 23, 2017 03:18 PM
dojo55
Mar 3, 2017 09:53 AM
87WE2
Sep 12, 2016 09:01 PM
Linson
Mar 3, 2015 08:15 PM
