need help wiring new distibuter in...
Old Jan 5, 2002 | 09:05 AM
zboss86's Avatar
I'm swapping over to an LT1 intake, and it requires the smaller distibuter with external coil from later model thirdgens for clearance.
I thought I had it wired up right but still no crank.
I noticed when I turn the distibuter to alter the timing , the speed it turns over doesn't change. (while I'm trying to start it) So I know that isn't right.
It is firing b/c it shows on the timing light.
I know it's set in right.
I'm not sure on the first two wires on the ignition module(A,B), and the wires on the iginition coil.
Does any body know a good wiring diagram for this setup? The Haynes manual just puts both distibuters together in one drawing.
Old Jan 5, 2002 | 12:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't know it this is any use to you but here's a diagram I made from the Haynes manual for a TPI 5.0/5.7
Old Jan 5, 2002 | 01:54 PM
zboss86's Avatar
thanks
appreciate it,
I'm pretty sure that I got wired right now. I'm thinking I got a bum distributer.
When I turn the distributer to advance or retard the timing, it stay the same.
Would the the ditributer cause that or has anybody ever even heard of that?
Old Jan 9, 2002 | 05:32 PM
89 4Mula 350 Tbi's Avatar
you probably dont have a bad distributor you might have a bad module or pick up coil. The reason the timing didnt change is because you probably didnt disconnect the brown or tan i forget which wire by the blower motor. This takes the computer out of the equation when doing base timing which you probably were trying to do. If you do not have that wire unpluged the computer will keep the timing the same no matter how much you turn the distributor. Rebuild the distributor but before you do that take it out and spin it you should feel 8 magnetic fields when you spin it slowly if you dont then replace the distributor shaft Personally since the distributor is coming out I would just rebuild it I did to my and its not that expensive.
Old Jan 10, 2002 | 08:44 AM
zboss86's Avatar
that's a thought
I'll try that this weekend when I get back from work, appreciate it.
zboss86
Caspar
Jun 19, 2016 11:19 PM
InfinityShade
Feb 21, 2016 01:29 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
