broke ignition wire
Re: broke ignition wire
VATS. Carries the signal from the pellet in the key to the computer. If your VATS is bypassed, don't worry about it. If your car still starts, you're good to go.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you need to bypass the key reader you can measure the key pellet resistance. Then instal a resistor of the same impedance at the bottom of the column .
The car should still start. I was scared to try but when i turned over the key everything seems fine, push to start button lit up. Still need to replace the steering column, because there is not enough wiring to pull out what I need to to get to those torx bolts that come loose.
glen_miss3
Oct 11, 2004 01:16 AM
Tuffguy610
May 9, 2001 12:23 AM
