Antenna downgrade
Old Apr 14, 2018 | 02:41 PM
johnw999's Avatar
Antenna downgrade
I don’t like my power antenna, and I plan to downgrade. It’s distracting, it occasionally pops a fuse, and it’s prone to mechanical problems. When I had a Toyota 4Runner, I read about the whip antenna mod. It was instructions on how to replace the power antenna with a standard antenna from a Toyota Tacoma. After my 4Runner’s antenna failed the 2nd time, I did the mod. It worked great. Hopefully I’ll have similar results. I bought a standard antenna mast from eBay (gm part #10026633). I’ll replace the antenna wire all the way back to the radio.
Old Apr 14, 2018 | 05:12 PM
Drew's Avatar
Re: Antenna downgrade
Having never owned a thirdgen with a power antenna, I can't say that the fixed mast antenna bothers me in the least. Even having to unscrew it when putting the cover on the car, it's really just not an issue.
Pretty sure the antenna assembly is easy to convert. On the fixed mast cars, it's just a 90* tab bolted to the body, with a 10mm bolt and star washer retaining the antenna base to the tab, then the bezel and nut on top of the fender. Not sure the power antenna uses the exact same tab, but even if not it'd be easy to fabricate.
Old Apr 14, 2018 | 09:17 PM
johnw999's Avatar
Thanks - the old antenna and wiring are out. The new antenna cable is in along with the grommet. I realized that I need a different bezel and retaining nut. I just bought those from Hawk’s third gen. I’m going to start with a small flexible antenna and see how it goes.
http://www.hawksmotorsports.com/ante...tenna-82-2002/
Old Apr 15, 2018 | 08:25 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
You guys that want to ditch the front antenna and still want good fm reception check out Tune Trapper, I took my antenna out and capped the hole, 2 good places to mount the antenna are beneath the dash pad and inside the headliner if you have t tops put it right in the center pointing front and back. I tried in both locations and it works amazingly well and no ugly antenna. I tried the center console that wasn't as good reception so don't mount there.
Old Apr 20, 2018 | 12:03 PM
johnw999's Avatar
I got the antenna mounted. I’m installing new carpet, so it will be a while before I can test the reception.
Old Jul 7, 2018 | 10:13 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
John how did this go? Deece FM from your major stations?
Old Jul 10, 2018 | 08:09 AM
johnw999's Avatar
I’m still refurbishing my interior. Once I get the car back on the road, I’ll post an update. The new antenna looks good, and the antenna wire was easy to route to the radio.
Old Sep 13, 2018 | 12:03 PM
johnw999's Avatar
I FINALLY finished my interior project. The project included a new alpine head unit, and I powered it up for the first time today. All FM stations sounded nice and clear. The AM stations had a little static, though. The seek passed over the talk radio station I usually listen to. I manually tuned in the station, and I could hear it fine. All in all, I’m happy with the small stationary antenna.
Old Jan 18, 2020 | 04:00 PM
Zarlor's Avatar
what did you use to cap the hole?
Old Jan 18, 2020 | 04:18 PM
johnw999's Avatar
If I remember correctly, the replacement antenna wire came with a grommet. The larger hole is from the ls swap with new engine harness.
tuononero
Nov 10, 2010 01:19 PM
31BiRd92
Jun 24, 2008 12:27 PM
5.8L Camaro
Sep 10, 2004 01:06 PM
92B4C3051LE
Aug 2, 2003 02:26 AM
Boxeat2469
Apr 22, 2002 09:15 PM
