1991 Pontiac Firebird Formula Turn Signals Do Not Flash
Old Apr 18, 2018 | 08:44 PM
Green91FF's Avatar
Car: 1991 Pontiac Firebird Formula
Engine: 5.7L 350 TPI
Transmission: TH700R4
Hello,
I have a 1991 Pontiac Firebird Formula 5.7L and when I turn on my turn signal to use either my left or right blinker they do not flash on my dash board nor does it flash outside the car. My high beam works, windshield washer works, wipers work, and my hazards work as well. I don't think I burnt a bulb either because my hazards all around the car work fine. Could someone please help me figure this out? Also, if anyone will be suggesting the flash could they also explain to be why and where I could find it under the dash, a picture of the flasher would be great too, that goes for the relay, if there is one. I'm eager to drive my car its been months lol!
Thank you
Old Apr 18, 2018 | 09:13 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: 1991 Pontiac Firebird Formula Turn Signals Do Not Flash
Originally Posted by Green91FF
Hello,
Thank you
Its a big bell like thing in the convenience center. The Convenience center is located above your right foot next to the transmission tunnel.
Fusebox is on the left side of the driver footwell, above the Hood release.
Convenience center is on the opposite side of the drivers footwell.
Old Apr 18, 2018 | 09:47 PM
Drew's Avatar
In 91, the turn signal flasher is the silver can clipped to the side of the fuse box, with a red plug. The similar can in the conv center is the hazard flasher.
Old Apr 21, 2018 | 08:01 AM
johnw999's Avatar
It could be the turn/hazard assembly in the steering column. I had to replace it on my ‘89 IROC a long time ago. Putting the telescoping steering wheel back together was not fun. And since you have a firebird with an airbag steering wheel... Oy Vey!
Old Apr 27, 2018 | 12:59 PM
Green91FF's Avatar
Thank you, I found it. I went to my local auto parts store and picked up a new flasher. After installing it everything worked.
Oddie65
Aug 21, 2014 05:09 PM
Cambird Z/AM
Jun 12, 2012 03:30 AM
Erich504Camaro
Mar 19, 2011 09:11 AM
jprix
Nov 22, 2010 10:04 AM
z28redline
Aug 24, 2005 05:05 PM
