Gauge illumination lights not working on 1985 pontiac firebird.
Old Jun 1, 2018 | 08:02 PM
Held's Avatar
All fuses are good. Headlight switch is good. Keep in mind I have had the interior carpet and center console pulled. Done some wiring under the dash for external gauges and replaced the engine so a wire could have been pulled somewhere. The warning lights in the gauge work but not the perimeter of the gauge lights work that illuminate the gauges themselves. Any wiring related to those gauge light please don't hesitate to recommend me to look at even if you think it might not be it. Thanks guys.
Old Jun 1, 2018 | 10:57 PM
PaulyC's Avatar
Re: Gauge illumination lights not working.
Anything else not working? Tell us more about the specifics of the car, year, camaro or ‘bird and anything else that may not be factory. No matter which flavor you have see if there are other lights that may be out as well that could clue us in to the problem. If you still have heater controls they are also on that circuit. If the backlighting is out also there and your Inst Lps fuse (should be 5A) is not blown(verify by checking for continuity not just by sight) you could be looking at a switch. If no 12v at the fuse, a fusible link is suspect, if heat control lights work maybe a bad or dirty connect in the cluster connector.
Old Jun 1, 2018 | 11:47 PM
Drew's Avatar
Do the backlights on the HVAC control come on? Grab a 12v test light and check for voltage at the extra terminal for gauge lighting in the fuse block. Think it's the one marked gauges, should be hot when the lights are on.
Old Jun 2, 2018 | 07:48 AM
Held's Avatar
oh crap stupid me. It's a 1985 pontiac firebird. Also the radio, temp gauge, volt meter, and oil pressure gauge are aftermarket. Meaning I bought the three in a row gauges and mounted them somewhere else. A lot of the wiring for emissions is disconnected since I went with carburetor. Not that that should have anything to do with it but just letting you know I've done a lot of work to it. But the lights when out way after I did all the engine work. And everything else works on the car, I do have the passenger side rear marker light unplugged do to bodywork I'm doing on that qauter panel. And the drivers side headlight just went out for some reason. Could just be a bad bulb though.
Old Jun 2, 2018 | 08:58 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Gauge illumination lights not working on 1985 pontiac firebird.
http://www.idmsvcs.com/2vmod/thirdge...mer/index.html
this fixed my issue of the dash lights not turning on with the headlights
86Stevo
Sep 16, 2013 01:02 PM
ROADKILL76
Nov 6, 2011 08:24 PM
blue86iroc
May 28, 2011 10:05 PM
Calderone
Jul 8, 2002 02:59 PM
