gauge illumination
Old Nov 3, 2011 | 02:36 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
gauge illumination
I finally got my TA road worthy but none of the gauges light up at all, they all do work but can see them at night. I checked the fuse and all I saw was an arrow pointing at a single terminal with nothing there, any thoughts?
Old Nov 3, 2011 | 06:00 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: gauge illumination
did you twist the light switch to see if they are dimmed?
Old Nov 3, 2011 | 10:25 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Yes, it on high
Old Nov 5, 2011 | 12:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
does the radio light up, or the ac controls?
Old Nov 5, 2011 | 01:17 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
The radio is aftermarket and does light up but the ac controls dont
Old Nov 5, 2011 | 01:55 PM
travis401's Avatar
Car: 91 Camaro RS
have you checked the fuses?
Old Nov 5, 2011 | 01:59 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
I did but there was only one slot/terminal instead of 2 but nothing there
Old Nov 5, 2011 | 09:46 PM
MNformula350's Avatar
did you try putting a fuse in?
Old Nov 6, 2011 | 09:13 AM
travis401's Avatar
Car: 91 Camaro RS
the one slot spots are for expansion. its ment to stick a single male spade terminal in to power stuff. the ones marked illum only get power when the lights are on. there should be a fuse for gauges or illumination or courtesy lights. does the dome light, cigerette lighter, or power locks work? if they dont then check the acc fuse. i cant remember if the lights run off that fuse too or not.
Old Nov 6, 2011 | 10:11 AM
Da Spudro's Avatar
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
there was another guy on here with that problem. turned out to by a short in his audible alarm (the thingy that makes noise when you put your keys in or leave your lights on after the keys removed). he also said he had a problem with his cruise control, but it doesn't seem to be tied into the circuit circled in green below.
Old Nov 6, 2011 | 08:24 PM
ROADKILL76's Avatar
Car: 1988 T/A
Engine: 305 TBI
Yea it was the fuse, the arrow next to it threw me off
Luigytico09
Oct 1, 2015 08:46 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
