another speedo ???
Old Jun 12, 2018 | 03:58 PM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
another speedo ???
I haven't found a clear cut answer in my searching but I have to take my motor one more time so no better time than to fix this.
I installed one of these but the speedo still doesn't work:
https://www.rockauto.com/en/moreinfo...035762&jsn=553
it is brand new. the tranny that is in the car is a v8, 700r4 with a 3000stall. there are two electrical plugs on the drivers side of it and both connectors are hooked up properly and still no speedo. the engine is of course not the v6. see in the sig. it is now 357 carb vortec. please help if you need any other info let me know. oh the tranny came out of a trans am with a cable driven speedo. and I have the proper gears so speedo is accurate. thx
Old Jun 12, 2018 | 04:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: another speedo ???
Put the ECM back in... You removed the VSS buffer when you deleted it.
Or,
Install an SGI-5 box.
Or,
Install a 4-Out Buffer box.
RBob.
Old Jun 13, 2018 | 06:27 AM
Car: 91RS
I have not removed the ecm except to or at least I don't remember taking it out unless it was when I replaced heater core. But I will check to see if wires came loose. And I'll check other options also. Thx
Old Jun 13, 2018 | 09:59 AM
Car: 91RS
Is this the buffer box your talkn bout
http://www.hawksmotorsports.com/86-9...ffer-box-used/
https://m.ebay.com/itm/DRAC-Module-c...d=350899836424
Old Jun 13, 2018 | 03:21 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes to the yellow Hawks buffer. No to the ebay DRAC.
Although for the price you would be better off with the SGI-5 box. The reason is that it allows for calibrating the VSS pulse rate to the speedometer.
RBob.
Old Jun 13, 2018 | 03:52 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Or you can install a cable driven speedo
Old Jun 15, 2018 | 10:02 AM
Car: 91RS
10-4 to both. Thx fellas
philoldsmobile
European Region
Sep 11, 2005 02:16 PM
flyitlikustolit
Apr 7, 2004 07:28 PM
MDv6man
Sep 6, 2002 03:08 PM
