Gauge lighting
Old Jun 15, 2018 | 08:53 AM
twentyyearwait's Avatar
Car: 1984 Z28
Transmission: TH350
Gauge lighting
I'm installing some aftermarket gauges in my 84 Z28. I'm wondering where to grab power from for the gauge lighting? This has probably been answered before so if someone could point me in the right direction that would help.
Old Jun 15, 2018 | 10:33 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Gauge lighting
In this diagram , the grey wire coming from the headlight switch , fused by the 5 amp "INST" fuse and leading into the audio alarm , is the wire you want to use for your aftermarket gauge lights . Do not use the dark green wire because then your lights won't be fused , and don't use the brown wire because then your lights won't dim with the rest of the dashboard (when using the dimmer , of course) .
Old Jun 15, 2018 | 10:34 AM
Drew's Avatar
Re: Gauge lighting
Look for the empty socket in the fuse block.
Old Jun 15, 2018 | 05:03 PM
Car: 1984 Z28
Transmission: TH350
Re: Gauge lighting
Thank you!
John91VertZ28
Feb 24, 2012 12:38 PM
a13rodie
Dec 12, 2006 02:15 PM
SLAYER6669
Aug 28, 2005 07:09 PM
KiLLa MiKe
Jun 12, 2004 11:28 PM
maddmonkees90rs
Jan 28, 2003 01:03 PM
