Wiper motor connector question
Old Aug 27, 2018 | 09:21 AM
Drone358's Avatar
I have a different wiring harness then the original make of the car apparently. I have the 6 wire connector on my harness but my car is a 92 camaro. What year should I look for on a wiper motor so my connector will work?
Thank you
Old Sep 10, 2018 | 08:27 PM
1986_IROC-Z's Avatar
Re: Wiper motor connector question
Thank you
The wiper motors changed throughout the years. IIRC, 90-92 should be interchangeable, maybe even 88-92 should work.
84-87 cars used a different setup with a nasty rube-goldberg type contraption for the delay mechanism, and the washer pump was in the motor itself (later moved to the fluid reservoir).
The other thing is, if just the motor is bad, you can get a remanufactured one and probably just swap the covers (black part on top). Hope that helps.
thewizard
Exterior Parts for Sale
Aug 17, 2017 01:29 AM
xbazzarex
Oct 2, 2016 11:43 PM
Ivekora
Sep 16, 2016 01:47 AM
T.L.
Sep 12, 2016 09:10 PM
Cnich92
Sep 12, 2016 04:53 PM
