Need help 92 Camero wipers will not work.
Old Sep 10, 2016 | 01:02 PM
Cnich92's Avatar
Car: 92 RS CAMARO
I have changed pulse board and wiper motor they will work when hooked up straight to power but will not turn on with the switch. What could cause them not to get power.
Old Sep 12, 2016 | 04:53 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Rain Pain
Make sure you have power on both sides of the WIPER fuse, located up and to the left of the brake pedal, behind a small door.
If there is, unplug wiper unit, put the key in the ACCY position, and the wiper switch in the HI position, use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the pink, dark green, gray, and purple wires.
Which wires do you have power on?
Happy Racing !
Nitromethane Smells Sweet Burning, But Please, No Roasting Marshmallows On The Zoomies
aussiesteve
Sep 15, 2016 06:10 PM
Ryan-87GTA
Interior Parts Wanted
Sep 12, 2016 01:52 PM
Cody Willey
Sep 10, 2016 05:38 PM
NiG
Sep 6, 2016 09:45 PM
qmcdugan
Sep 4, 2016 11:40 PM
