Alternator and electrical headaches.
Old Aug 31, 2018 | 11:39 AM
Blue Pearl's Avatar
1987 Camaro 305 TPI
So the other day I noticed that electrical hum coming from my alternator with the key off. Its charging weak at or just below 13v. My guess was a diode or internal part went bad inside the alternator. But after some poking around and looking at wiring diagrams, there seems to be confusion as to what wire is the exciter for the alternator. Most sources say the brown wire is the excitor wire. At my alternator i have:
batt+ voltage at the large terminal.
Batt+ at the red “S” wire.
Batt+ at the brown/white “F” wire
nothing at the brown “L” wire.
To my understanding i should have nothing at the brown/ white and ign switched resisted voltage at the brown wire.
And to add to the confusion, some things have power supplied all the time that i believe should not. My power windows mirrors, hvac blower will work with the key removed. Havnt had much luck finding power distribution info but could this be ign switch related?
Gauges/dash lights/ fuel pump seem to cycle normally with key. Anybody have any input before i put in a new alternator?
Old Aug 31, 2018 | 01:13 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Alternator and electrical headaches.
https://www.thirdgen.org/forums/electronics/634092-alternator-not-charging.html#&gid=1&pid=1
Post 21 by TreeFiddy
Old Aug 31, 2018 | 06:14 PM
Blue Pearl's Avatar
The wires that connect to my alt are red, brown, and brown/white. And of course the main red wire from the post to the batt. I’m seeing different responses as to what each wire’s function should be.
Old Aug 31, 2018 | 06:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'm not familiar with your alternator, but usually,
S terminal (Sense) is used as a voltage reference for the voltage regulator. The alternator will keep charging until it sees proper voltage at that sense terminal. If nothing is connected to the S terminal then the alternator will reference its own internal voltage instead. Alternator should work whether or not anything is connected to the S terminal.
L terminal (Lamp) is used to turn a light bulb on and off as a charging indicator. It is not needed for the alternator to function.
F terminal (Field) is the excitation wire. It must be connected for alternators that require external excitation. It does not need to be connected for alternators with internal excitation. I do not know the specifications for your alternator.
The I terminal is like an F and L terminal combined into one. It needs a resistor on the external wire to lower current draw, otherwise the alternator will be damaged.
Old Sep 1, 2018 | 03:35 PM
Blue Pearl's Avatar
that makes some sense with the wires that I have. I have battery voltage at my brown/white F wire. Is that safe or does that need to have a resistor?
And maybe the hum is there because the alt is being “excited” at all times when it should only be while the key is on. Any clues as to how that could happen?
.. i’ll try and put more info about the alt later, but i know it’s a reman with the 3 wire connector.
Old Sep 3, 2018 | 12:41 PM
Blue Pearl's Avatar
So does anyone know where this brown/white wire gets its power from? An ignition relay somewhere?
Old Sep 7, 2018 | 03:01 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Call the Delco Remy service help line. Get answers you can trust.
http://www.delcoremy.com/Support
Camarogeddon
Apr 4, 2004 03:22 PM
boggledinstl
Jun 16, 2002 06:26 PM
un4givin89
Car Audio
16
Dec 28, 2001 09:37 PM
CamaroZ_85
Aug 18, 2001 05:44 PM
RS'er
Feb 10, 2001 11:47 AM
