Quirky defroster switch
Old Sep 10, 2018 | 06:24 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Engine: 90-95 ZZ4 Crate 350 TPI
Transmission: 700R4 4spd Automatic
Axle/Gears: 3:73
Got a strange one for you electrical gurus on board.
So I'm traveling on my fresh 305/350 swap out finally after a year of trials and tribulations and noticed that my rear window defroster switch activates when I hit the brakes. Kept turning it off until I got home and pulled in the garage for a closer look.
Come to find out the second I hit the brakes, the switch does come on and when I went outside and checked the brake lights, the main ones were off but the 3rd brake light was still illuminated, so I reached into the cab and switched the defroster off and then looked outside again and the darn thing was off.
This one has me scratching my head. Looked at the schematic in my Chilton book and cant seem to find the defroster switch. (maybe I need new glasses) But if anyone can help me figure this one out, it would be most appreciated.
Thanks!!! Steve
Old Sep 10, 2018 | 06:26 PM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
Re: Quirky defroster switch
I was maybe thinking about the ground wires, which I had to relocate further down on the block because of the head swap out to Edelbrock aluminum vortec heads....
Old Sep 10, 2018 | 06:46 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You might want to look at your grounds. This doesn’t show ground distribution but a gm electrical service manual would.
http://www.austinthirdgen.org/?pid=19
Old Nov 25, 2018 | 10:04 AM
SRKLEGIN's Avatar
Car: 1986 IROC-Z
Axle/Gears: 3:73
So I did some chasing around the compartment and discovered that the RH Aft deck strut connection had came loose. Problem solved...LOL...wow...that simple
Thenewt078
Aug 15, 2017 05:51 AM
musclecar70sfan
Brakes
Oct 2, 2010 09:31 PM
1981LT1
Mar 13, 2010 08:55 PM
L695speed
Aug 23, 2009 08:52 PM
anthony714
Oct 2, 2006 11:22 PM
