High reference voltage to sensors
Old Sep 12, 2018 | 01:30 AM
aj-ajay's Avatar
Car engine is stalling. The MAP sensor is receiving 5 volt with switch on and engine off, but with engine on this voltage increases to 6.5 volt.This causes high voltage from signal wire of MAP sensor to ECM, causing increased fuel supply to manifold. This causes engine to stall.
Old Sep 12, 2018 | 06:16 AM
aj-ajay's Avatar
Re: High reference voltage to sensors
Is it a failing ECM
Old Sep 12, 2018 | 10:40 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Originally Posted by aj-ajay
Is it a failing ECM
maybe rbob will chime in. It sounds like a bad ecm.
Old Sep 13, 2018 | 12:57 AM
aj-ajay's Avatar
Pl anybody with sound understanding help, before I get ECM open
Old Sep 13, 2018 | 11:33 AM
Engine: Lb9
Transmission: M20
I’m assuming you have a 730 ecm and might have a code 33.
there is a step showing 1v or less if higher possible bad ecm.
http://www.chevythunder.com/map_code_33.htm
Old Sep 14, 2018 | 02:11 AM
aj-ajay's Avatar
I think there is problem with the alternator rectfier, which may be sending some AC currrent when the alternator is running. This may be the cause of ECM erratic respone in the form of higher fluctuating reference volatge in the MAP sensor when the engine is running. But when engine is off the reference voltage comes back to normal 5 volt range. Pl see if this can also be one possibility...
ndndndnd
Oct 30, 2017 05:27 PM
fenderman93
Apr 27, 2017 09:05 PM
88irocz28
Dec 6, 2001 06:30 PM
88irocz28
Mar 31, 2001 08:32 AM
