Blower motor conundrum
Old Oct 10, 2018 | 05:20 PM
Roblaza's Avatar
Hey guys.
So I have an 89 rs that originally came with AC. I removed the AC as it no longer worked and installed a factory metal non AC heater box.
Here is where the issue lies...when I hook the blower motor up and command it on from the control unit inside the car everything works fine and it spins with no issues. I have swapped the cage to the shallower non AC cage to work with the non AC box.
BUT when I bolt the blower motor and resistor into the box, it gives up and doesn't even try to spin. What am I missing?
Old Oct 15, 2018 | 09:30 PM
namdlo's Avatar
Re: Blower motor conundrum
I aint no expert but in most electrical conundrums its grounds that are causing the problem. I work mainly on cars and trucks from the 70s but I have found that these 80s and 90s Camaros get ungrounded. don't trust in harness grounds . run a separate ground from the blower motor to the hood hinge or something else metal and see if that helps.
Old Oct 17, 2018 | 09:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Got Ground ??
Arctic Cat ZRT
Jan 12, 2015 10:47 AM
haps
Nov 23, 2014 02:02 PM
//<86TA>\\
Aug 9, 2010 12:22 AM
tguen108
Aug 19, 2007 02:01 AM
xity
Mar 11, 2007 12:27 AM
