D12 wire
Old Nov 29, 2018 | 05:00 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
D12 wire
Hi guys, since I’ m restoring the original wiring in my car I noticed this wire, which is the D12 coming from the ECM. Where do I solder it to? I guess there’s another cut blue wire somewhere... the ECM is 1227730, auto trans, 3.1 V6 Lh0. Here’s a pic, thanks in advance!
Old Nov 29, 2018 | 08:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: D12 wire
Goes to the A/C pressure switch. Leaving it open like that should have the cooling fan running whenever the engine is running.
RBob.
Old Nov 29, 2018 | 08:32 AM
Engine: 3.1 LH0
Re: D12 wire
It was grounded with the strap on the firewall. Can’t believe how much this car is messed up with the wiring harness...
Old Nov 29, 2018 | 10:53 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: D12 wire
Old Nov 29, 2018 | 12:23 PM
BizJetTech's Avatar
Re: D12 wire
RBob.
Actually, wire 731 gry (ECM BD12) goes to pin F of the secondary fan relay (relay coil), by grounding that wire, the secondary fan will run all the time.
If that was was not connected (open circut) the secondary fan would not run - at least that is what it looks like to me....
Old Nov 29, 2018 | 12:36 PM
Engine: Lb9
Transmission: M20
Re: D12 wire
The ecm controls the primary fan when ac is requested.
Old Nov 29, 2018 | 12:46 PM
BizJetTech's Avatar
Re: D12 wire
Yes, that is correct, but that has nothing to do with the wire in question....
Old Nov 29, 2018 | 03:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: D12 wire
Tuned, that diagram is for $8D, this is the one for $88:
RBob.
Old Nov 29, 2018 | 03:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: D12 wire
I guess the A/C system is gone or doesn't work? By grounding that wire to the firewall, this prevents the ECM from running the fan thinking the A/C system is being used (high pressure). Note that on factory delete A/C cars ('90 - '92 MPFI), GM did the same thing.
RBob.
Old Nov 29, 2018 | 03:59 PM
BizJetTech's Avatar
Re: D12 wire
RBob.
Well then......grounding wire 732 dk blue that goes to the ECM BD12 will bypass the A/C fan press switch (which I assume was done because of a
faulty A/C press switch stuck in the open position)
Old Nov 30, 2018 | 07:54 AM
Engine: 3.1 LH0
Re: D12 wire
RBob.
The system never worked properly since I bought the car, the engine went rough and occasionally stalled when the A/C was on. Over time I tried to turn the A/C on occasionally, but the clutch never started again. So I noticed this wire when trying to restore the original wiring...
Old Nov 30, 2018 | 07:56 AM
Engine: 3.1 LH0
Re: D12 wire
Thank you all guys, now it' s much more clearer to me! Where' s exactly located the A/C fan pressure switch? I guess the only thing I have to do is to connect that wire to it…
Old Nov 30, 2018 | 09:30 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: D12 wire
Passenger side.
RBob.
Old Nov 30, 2018 | 03:16 PM
Engine: 3.1 LH0
Re: D12 wire
Great, thank you!!
Old Dec 5, 2018 | 01:13 PM
Engine: 3.1 LH0
Re: D12 wire
Ok, I’ m trying to find the other side of the wire but I can’t find it... I checked the continuity between the pressure switch and it’s cut wire, it’s okay. Now, which is the path to follow to find the other wire? I’m attaching two pics to let you see a little better.
Old Dec 5, 2018 | 01:26 PM
BizJetTech's Avatar
Re: D12 wire
...."I checked the continuity between the pressure switch and it’s cut wire, it’s okay"......
That is meaningless.....not sure where you are going with that troubleshooting....
The wire in question runs from the pressure switch terminal B to BD12 at the ECM - if a wire is connected
to the pressure switch terminal B and cut before it reaches the ECM splice in a new wire and run it to the ECM - it's that simple
What "other wire" are you looking for ??
Old Dec 6, 2018 | 12:56 AM
Engine: 3.1 LH0
Re: D12 wire
That’s the point, B and D12 are connected regularly, but there’s a junction that was grounded with the strap on the firewall. Is that the original wiring? If so, I’ ll stop to hunt ghosts in my hood!
Old Dec 6, 2018 | 09:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: D12 wire
The ground wire for the A/C fan pressure switch goes to the rear of the right hand cylinder head. Circuit 450 (BLK/WHT) and ground G118.
RBob.
Old Dec 6, 2018 | 10:22 AM
Engine: 3.1 LH0
Re: D12 wire
Great, thanks a lot!!
84Elky
Jul 22, 2012 12:14 PM
mr420joe
Oct 12, 2009 10:18 PM
iggy1991
Feb 27, 2005 12:39 AM
Todd 92 Z
Car Audio
Jan 30, 2001 04:14 AM
