ACC fuse blowing - HELP
Old Nov 30, 2018 | 04:03 PM
WidowMaker17's Avatar
Car: 1987 Camaro LT
Engine: LG4 V8
Transmission: Automatic
So as the title says my ACC fuse is blowing, and yeah I’ve checked the easy solutions like the cigarette lighter, radio, horn, and the power mirrors. I don’t know where else to check, but it’s to the point where it won’t even let me touch it with a new fuse before it blows the damn thing.
I have an 87 camaro LT with a 305 5.0L. I’m out of ideas, I’m out of carrots, I’m out of sticks. I love this car but I can never keep the damn thing consistent. It’s always one new problem after another. I found out the ECU is bad today. I don’t know anymore. If anyone has an idea on where else for me to look for the issue with the fuse please let me know.
Old Nov 30, 2018 | 08:11 PM
Drew's Avatar
Re: ACC fuse blowing - HELP
Well, you need to get the wiring diagram that shows the circuit that runs off that fuse. Then you can try to eliminate possibilities, or trace the entire circuit looking for a pinched wire, or short to ground.
Old Nov 30, 2018 | 09:41 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
9 out of 10 times it’s the cigarette lighter. Did you disconnect the connector on the back of the cigarette lighter yet?
Old Dec 1, 2018 | 12:06 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Buy yourself a couple of boxes of 20-amp fuses and start unplugging/plugging in stuff?
jagevileye21
May 1, 2009 07:22 PM
Camaro_dude92
Apr 25, 2009 05:42 AM
primerinstinto
Sep 15, 2003 03:31 AM
un4givin89
Nov 26, 2001 03:03 PM
GTA88
Nov 16, 2000 03:34 PM
