Ls swap wiring/ignition cylinder questions
Old Jan 20, 2019 | 12:40 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
hey guys, just a quick question for you all! I have an 89 firebird with an ls swap in it and am finishing up wiring but just some things that I can’t seem to figure out. When I went to turn on the ignition, I turned it to the RUN position and I didn’t hear the pump turn on and nothing lit up on the gauges. But when I rotated the key to the START position, all of my aftermarket gauges lit up and and the pump started running. I have the whole fuse/relay block for the main relay, fuel pump, and fuses for the standalone engine harness wired with a 12V battery and then used the thick pink wire that originally went to the distributor as the ignition 12V. Also, the ignition cylinder feels very mushy and spongy when I rotate it from one position to the next, so I replaced the cylinder and it feels the same way. Can anyone tell me if I have a wiring issue or also what could be causing the mushy ignition cylinder? Thanks in advance, Jeremy
Old Jan 23, 2019 | 06:37 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: Ls swap wiring/ignition cylinder questions
Bumppp
Old Jan 23, 2019 | 11:01 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The actual switch is down on the column, its easy to damage the linkage etc if you have taken the column out. I would take the switch out and test to make sure its feeding the right pins in the right position. Then verify the cylinder is moving the switch to the right positions when you turn the key. This is driven by a metal rod down the column.
I don't have my schematics handy right now but I believe if you used the old distributor 12v wired to turn on all the relays in the stand along box, and the purple wire is going to the starter then it should at least prime the fuel pump in the run position.
The other issue could be the power that feeds the internal fuse box, is that hot all the time? could it be that you have those wired so they only provide power in the crank position.
Also did the car have VATS? if so bypass the relay in the kick panel. Or make sure the VATS module is grounded (its ground is over with the old ECM wiring) I've posted on how to keep VATS as a starter disable and the LS1
Old Jan 23, 2019 | 07:32 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
hey man, got to work on the car today and I can answer your reply properly and I couldn’t without looking at everything previously. So I ordered a new ignition switch and put that in today. It was a total b*** to get out with the cable that is attached to it!! I put in the new switch and I still had the same situation but then I kinda wiggled the switch before I bolted it completely back down and it ‘magically’ fixed the issue and the key went to the positions it was supposed to. I turned the key to the RUN position and my auxiliary gauges came on, the pump started running, and the pcm got power. I did disable vats in the car by connecting the two wires in the kick panel but have thought about going back and making it an anti-theft device somehow.
3.8TransAM
Jul 5, 2015 07:23 PM
3.8TransAM
Apr 5, 2015 01:27 AM
BlueZee28
Oct 6, 2013 08:33 PM
89badass
Jun 1, 2010 07:14 PM
