1987 Firebird TPI Coil/Tach Harness Question
Car: 1987 Formula
Engine: 383
Hi guys,
I'm trying to track down where the other end of this ignition coil harness connects to. I've been looking at the harnesses in the car, but can't seem to find another connector that would fit this. I originally thought all four coil wires went straight into the main harness, but when i couldn't find the second pink and white wires, i went looking in my parts stash and found this, which has the coil connector on one end. I need to find out where the other end goes, as i believe the white wire is for my tachometer and i'd very much like to hook it up.
<blockquote class="imgur-embed-pub" lang="en" data-id="a/l2xFBxY"><a href="//imgur.com/l2xFBxY"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
https://imgur.com/a/l2xFBxY
Thanks,
Steve
Thanks,
Steve
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1987 Firebird TPI Coil/Tach Harness Question
That one goes from the coil to the distributor where it plugs into the ignition module
Car: 1987 Formula
Engine: 383
Thanks, I was thinking that might be the case, but wasn't sure. Sadly that doesn't fix my tach problem then. Connecting the signal wire from my Crane box to the other white wire doesn't get it working, unfortunately so i'm back to square one.
michael
17
Jun 25, 2015 08:36 PM
roguecoxnet
Oct 15, 2014 03:14 PM
PLANT PROTECTION
Jun 14, 2003 10:53 AM
86TpiTransAm
Apr 24, 2001 11:55 AM
