Heater fan keeps popping fuses!!
Old Jan 9, 2002 | 12:15 PM
Nasty_Bird_'90's Avatar
hey guys. i have a problem with my heater motor. it keeps popping fuses. i tried a new motor, but the problem still exists. has anyone had a problem like this before? thanx
Old Jan 9, 2002 | 04:47 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
It sounds like something in the blower motor wiring a wire is grounding out. How long does it take for the fuse to blow? If instantaneous then it is definitely something grounding out. Does it pop fuses at every fan speed?
Old Jan 11, 2002 | 11:31 AM
It will run for quite a while before it blows. I don't think it's shorting out anywhere because it takes a while for the fuse to pop. I've been trying to igure out exactly when it blows, but haven't figured it out yet. It seems to be going every third or fourth time i start the car or somewhere between the time i shut it off ( the car) and restart it. I put a new motor in it, checked the resistors in the circuit, and they were fine. This leads me to believe that there must be something wrong with the switch because thats the only other thing in the circuit. any suggestions? thanx
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Grant2k
Apr 4, 2016 08:21 AM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
