Alternator Options...?
Old Jun 2, 2019 | 02:25 PM
JonJon5.0's Avatar
My 91 RS got a bad alternator it’s a 305 I got a alternator from a 2002 Chevy suburban with a 5.3L Vortec i bolted it on but the Connectors is different can I cut the positive feed wire from the truck harness and crimp it to the 3rd gen Harness and plug it in will this actually work ?
I never done it before but my elders told me it’s a old small block Chevy trick of the trade they used to do back in the day oh and my battery is brand new
Old Jun 2, 2019 | 03:02 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Alternator Options...?
I'd recommend you obtain a new or quality reman stock alternator and install it. it was good for millions of GM vehicles, why monkey around?
Old Jun 2, 2019 | 03:21 PM
JonJon5.0's Avatar
This Alternator was $30 and rock auto wanted $60 I choose the cheaper option that’s why I’m trying to make this work due to limited budget at this time
im starting to have second thoughts though...
Old Jun 2, 2019 | 04:05 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if the suburban alternator you mounted is an AD244,there are a few threads on here about using those in 3Gs.
Old Jun 2, 2019 | 11:12 PM
JonJon5.0's Avatar
This was a fail I’m just gonna buy the $60 one I screwed up it’s whatever everybody makes mistakes
Old Jun 3, 2019 | 01:13 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Everybody make mistakes. I wish you luck. FWIW, Rockauto is my first source on lots of parts. But on alternators, starters and sometimes waterpumps, I check locally also, because they usually have lifetime warranties and shipping one of those back, for an exchange is not something I would want to do.
Well, I just checked Orieley and they get $106 for a lifetime reman, considerably more than rock.
Old Dec 24, 2023 | 03:49 PM
Nutro's Avatar
Ok so I hooked up the battery and have 12V constant on body harness red and key on 12v at tan. I hooked the tan body wire to the F terminal on Alt and started car and I'm getting 13.42V at idle. It's all been sitting for a week or 2 with no run time.
Old Dec 24, 2023 | 07:37 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
13.42V is above the Open Circuit Voltage of battery..... Alternator is definitely charging.
J0hn_J0hn08
Mar 16, 2015 07:59 PM
Veaceonee
Jan 19, 2013 10:19 PM
evilemokid94
Nov 5, 2012 06:54 PM
