Stripped headlight gear how to get up for replacement
Old Jun 21, 2019 | 12:42 PM
RandyNJ's Avatar
Every video I look at and everything I read shows how to replace the motor or gear once you get the light up. I can't get it up with the manual **** and it doesn't come up at all normally. I've tried pulling with my hand as the motor spins automatically, but it didn't budge one bit. Is there any other way to possibly get it to come up?
Old Jun 30, 2019 | 09:18 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Stripped headlight gear how to get up for replacement
It will come up, you've just waited a bit too long to do the repair and have turned a one man job into a 2-person job. Have someone press on and off the headlight switch while you shake, bang lift and curse the headlight bucket lid. It will suddenly rise if you haven't run out of curse words. Once you FINALLY get it to raise you'll be able to follow the instructions that come with the kit.
Good luck with the repair.
Lon Salgren
Top-Down Solutions
Old Jul 1, 2019 | 10:55 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I just took the head light assembly off the car when I did mine and painted all the little parts before putting it back together.
Mine would come up if I pulled up slightly as I turned the manual ****.
Bobby_80s
Jun 27, 2012 08:02 PM
DacMan
Feb 28, 2011 10:40 PM
GTAman
Jan 4, 2004 09:52 PM
Arntzman
Nov 18, 2001 06:29 PM
