3 pin or 2 wire
Subscribe
Jul 2, 2019 | 02:50 PM
Hi, I apologize if this is already posted but I could not find it. I am wanting to buy a new battery cable set from Hawks 3rd gen. My dilemma is I dont know if I have a 3 pin set up or 2 wire set up. I have a 91 rs 305L V8 5 speed. I not exactly sure where to look, I see there in a 4pin connector with 2 wires coming out of it that connects to the alternator and what I think is a ground on the back of it. Any help would be great, Thanks
Reply 0
Jul 2, 2019 | 03:54 PM
Re: 3 pin or 2 wire
Question you should pose to Hawks 3rd gen,......... ????? Be sure to specify that's it's for a Camaro too.
Reply 0
Jul 2, 2019 | 04:07 PM
Re: 3 pin or 2 wire
I did on June 18 and sent pics as they requested and followed up on June 24th with them but no response as of now.
Reply 0
Jul 2, 2019 | 06:14 PM
Battery Up
If you have a dash voltmeter you have a 2 wire setup.
That is not a ground on the back, that goes to the battery.
That back nut is close to the valve cover, therefore make sure you disconnect the battery before unbolting that one.
Also, you are missing the rear alternator support bar.
Happy Racing !
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Reply 1
Jul 3, 2019 | 02:12 PM
Re: Battery Up
Thank you for that info, I didnt realize the alternator support bar was missing since when I got it it wasnt there either. I appreciate the help.
Reply 0
Subscribe
