Tachometer woes
Old Jul 28, 2019 | 05:59 PM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Tachometer woes
So I just got my instrument panel back in after being out for so long, I know I need to get a new printed board for the instrument panel, but that's later.
However the tachometer is pegged. The tach worked fine when I removed it.
Would the circuit board do this? Or is it a different issue?
305 5 speed. If that makes a difference.
Thanks in advance
Old Aug 22, 2019 | 01:13 PM
marshall lawson's Avatar
Car: '88 IROC
Engine: 305 TBI
Re: Tachometer woes
The tach on my '88 Camaro is usually pegged at the top too whenever the key is on. Unfortunately it was like that when I bought it, the previous owner screwed up a lot of stuff worse while he was working on it. He said he might have put in a few connections with the wrong polarity. I haven't opened up the dash yet because it's a lower priority compared to some problems that make the car physically not road safe, but I'll watch this thread and share whatever I learn when I get to dealing with mine.
Old Aug 26, 2019 | 04:49 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Tachy Indicator
There is circuitry in the dash near the tach.
It’s contained on a small plug-in PCB or integrated in the main board.
On or near the PCB you’ll see a capacitor, replace it.
Also on the PCB you’ll see a resistor chip.
Desolder pins 4 & 10.
Use a 500K potentiometer.
Solder it across traces 4 & 10.
Move the potentiometer to half way.
Start the engine and compare the tach reading with a test equipment quality tach.
Dial it in, unsolder the potentiometer, measure it and install a matching resistor.
Happy Racing !
I Smacked The Wall With The Side Of The Car Because A Narrower Car Is A Faster Car
zgunz57
Jun 1, 2017 05:43 PM
mjdavis68
Oct 5, 2015 03:46 PM
Sparten2068
Mar 3, 2014 05:00 PM
Chevy86 IROC-Z
Apr 20, 2010 03:11 PM
livinforhim
Oct 8, 2009 08:19 AM
